The operation being performed required a VR in the state other than the state shown. This is an internal state inconsistency and is generally very bad.
Check to see if VRRP state is correct. If the state is incorrect try disabling and re-enabling the VRRP instance.
Critical
Unexpected state: %state%
| Name | Type |
| state | String |
